针对TCL液晶电视MS28机芯主板,更换主板后参不对,导致液晶屏不显示,屏参盲调的方法:多按几次“退出”键,退出菜单,遥控器按 “信源+6259+菜单+XXX”其中,XXX为需要更改的id号,不足3位时前面需补足0,例如:想要设置屏参号号为3,按“退出”键后,输入 “信源6259菜单003”;设置成功后会自动进入待机状态,重新遥控开机即可(屏参ID号参考下面图表)
机器型号 |
Project_ID |
L32E5200 |
1 |
L55E5200BE |
2 |
L40F3200B |
3 |
L32V6300 |
4 |
L37V6300 |
5 |
C42P820 |
6 |
C47P820 |
7 |
C37P820 |
8 |
C32P820 |
9 |
L32F3200B_AU5 |
10 |
L32P50E_AU1 |
11 |
L42F3200E_AUJ |
12 |
L55P7200_SSA |
13 |
L46P7200_SS8(下乡) |
14 |
L42P7200_CM3(下乡) |
15 |
L32P7200_SS3 |
17 |
L37V6300_SDF1 |
20 |
L32F3200B_SS3 |
21 |
L46F3200E_SS6 |
22 |
L40P7200_SS6 |
23 |
L55E5200BE_LTA550HJ12 |
24 |
L32V6300_LC320EUN-SDF1 |
25 |
L32E5200BE_SS3 |
26 |
L32E5200BE_SS2 |
27 |
L42E5200BE_AUJ |
28 |
L46E5200BE_SS6 |
29 |
L37E5200BE_AU3 |
30 |
L40E5200BE_SS4 |
31 |
32 |
L42P21FBD_AUJ |
33 |
L46P21FBD_SS6 |
34 |
L32E5200BE_SSA |
35 |
L32F3200B_SSA |
36 |
L32BIAN3_SS3 |
37 |
L40BIAN3_SS6 |
38 |
L42BIAN3_CM3 |
39 |
L46BIAN3_SS8 |
40 |
L55BIAN3_SSA |
41 |
L46P7200_CM3 |
42 |
L32E5200_BK4 |
43 |
L46V6200_AU4 |
44 |
L42V6200DEG_BK3 |
45 |
L32V6200DEG_BK3 |
46 |
L37E5200_BK |
47 |
L32E5200_CL1 |
48 |
L37E5200_CM1 |
49 |
L46P6100_CM2 |
50 |
L55P6100_CM1 |
51 |
L42P6100_CM2 |
52 |
L42P21FBD_BK6 |
53 |
L32V6200DEG_SSC |
54 |
L46V6200_SS7 |
55 |
L40P7200_C04 |
56 |
L46P7200_C03 |
57 |
L55P7200_C03 |
58 |
L40BIAN3_C04 |
59 |
L46BIAN3_C03 |
60 |
L55BIAN3_C03 |
61 |
L55E5200BE_LTA550HQ14 |
62 |
L46E5200-3D_SSAP |
63 |
L55E5200-3D_SSAP |
64 |
L42P6100_CM2 |
65 |
L42V6300_AU1 |
66 |
L42V6300_LG2 |
67 |
L47V6300_LG1 |
68 |
L55V6300_AU4 |
69 |
L42E5200BE_BK6 |
70 |
L40E5200BE_SS3 |
71 |
L46V6200_AU1 |
72 |
L42E5200_CM3 |
73 |
L42P7200_CM7 |
74 |
L42E5200_CM5 |
75 |
L42P7200_CM5 |
76 |
L46E5200_CM4 |
77 |
L46P7200_CM4 |
78 |
L32P7200_CMO |
79 |
L43E5000_SS1 |
80 |
L48E5000_SS2 |
81 |
L32E5200BE_AU6 |
82 |
L40E5200-3D_SS6P |
83 |
L55P7200_3D_SSA(WIGET) |
84 |
L46P7200-3D_SS8(WIGET) |
85 |
L40P7200_3D_SS6(WIGET) |
86 |
L46P7200_3D_CM4(WIGET) |
87 |
L42P7200_3D_CM3(WIGET) |
88 |
L42P7200_3D_CM5(WIGET) |
89 |
L37E5200_AUTTE1 |
90 |
L39E5000-3D_LS5 |
91 |
L43E5000_SS3.ini |
93 |
L32E5200_LG2.ini |
94 |
L26E5300_P03 |
95 |
