| 故障代码 | 故障原因 | |||
| 运行灯 | 定时灯 | 自动灯 | 除霜灯 | |
| 5Hz | 5Hz | 5Hz | 压缩机过流保护 | |
| 5Hz | 5Hz | 5Hz | 5Hz | 室外保护(缺相,相序错及排气温度保护) |
| 5Hz | 室内温度传感器异常 | |||
| 5Hz | 5Hz | 室内管温传感器异常 | ||
| 5Hz | 室外温度传感器异常 | |||
| 5Hz | 5Hz | 风机外壳温度保险熔断 | ||
| 报警灯以5Hz闪 | 水位报警器报警 | |||
| 故障代码 | 故障原因 | |||
