格力户式机组双系统空调故障代码表
2014-03-16作者:Voyager整理1743
| 故障代码 |
故障原因 |
机组状态 |
复位方式 |
| E1 |
压缩机1高压保护 |
STOP |
SET |
| E2 |
系统1防冻结保护 |
STOP |
AUTO |
| E3 |
压缩机1低压保护 |
STOP |
SET |
| E4 |
压缩机1排气温度保护 |
STOP |
SET |
| E5 |
压缩机1过载保护 |
STOP |
SET |
| E6 |
水泵过载保护 |
STOP |
SET |
| E7 |
水流开关保护 |
STOP |
SET |
| E8 |
风机1过载保护 |
STOP |
SET |
| E9 |
系统1防高温保护 |
STOP |
AUTO |
| b1 |
压缩机2高压保护 |
STOP |
SET |
| b2 |
系统2防冻结保护 |
STOP |
AUTO |
| b3 |
压缩机2低压保护 |
STOP |
SET |
| b4 |
压缩机2排气温度保护 |
STOP |
SET |
| b5 |
压缩机2过载保护 |
STOP |
SET |
| b8 |
风机2过载保护 |
STOP |
SET |
| b9 |
系统2高温保护 |
STOP |
AUTO |
| F1 |
防冻温度传感器1故障 |
STOP |
AUTO |
| F2 |
防冻温度传感器2故障 |
STOP |
AUTO |
| F3 |
除霜感温包1故障 |
STOP |
AUTO |
| F4 |
除霜感温包2故障 |
STOP |
AUTO |
| F5 |
排气感温包1故障 |
STOP |
AUTO |
| F6 |
排气温度传感器2故障 |
STOP |
AUTO |
| F7 |
室外环境温度感温包 |
STOP |
AUTO |
| F8 |
进水温度传感器 |
YES |
AUTO |
| F9 |
出水温度传感器 |
STOP |
AUTO |
| EC |
通信故障 |
STOP |
AUTO |
| EE |
存储芯片故障 |
STOP |
SET |
