加西贝拉VN系列R600a变频压缩机是加西贝拉压缩机有限公司出品的一款产品,公司位于浙江省嘉兴市,是一家环保、节能、高效冰箱压缩机的制造企业,加西贝拉VN系列压缩机技术参数表如下:
| Compressor | Displ. | Motor | Fre. | 制冷量Capacity | COP | |||||
| Model |
Type |
ASHRAE | CECOMAF | ASHRAE | CECOMAF | |||
| 压缩机型号 | 气缸容积 | 电机型式 | 频率 | W | BTU/h | Kcal | W | W/W | BTU/Wh | W/W |
(cm3) |
(Hz) | |||||||
| VTU1070Y | 5.00 | BLDC | 40(1200rpm) | 38 | 130 | 33 | 29 | 1.63 | 5.56 | 1.27 |
| 53(1600rpm) | 50 | 171 | 43 | 38 | 1.65 | 5.63 | 1.29 | |||
| 80(2400rpm) | 75 | 256 | 64 | 56 | 1.65 | 5.63 | 1.29 | |||
| 100(3000rpm) | 90 | 307 | 77 | 68 | 1.62 | 5.53 | 1.26 | |||
| 150(4500rpm) | 130 | 444 | 112 | 98 | 1.6 | 5.46 | 1.25 | |||
| VTH1111Y | 7.20 | BLDC | 40(1200rpm) | 55 | 188 | 47 | 41 | 1.7 | 5.80 | 1.33 |
| 53(1600rpm) | 75 | 256 | 64 | 56 | 1.75 | 5.97 | 1.37 | |||
| 80(2400rpm) | 108 | 369 | 93 | 81 | 1.78 | 6.07 | 1.39 | |||
| 100(3000rpm) | 134 | 457 | 115 | 101 | 1.75 | 5.97 | 1.37 | |||
| 150(4500rpm) | 180 | 614 | 155 | 135 | 1.62 | 5.53 | 1.26 | |||
| VTH1113Y | 8.90 | BLDC | 40(1200rpm) | 65 | 222 | 56 | 49 | 1.7 | 5.80 | 1.33 |
| 53(1600rpm) | 85 | 290 | 73 | 64 | 1.75 | 5.97 | 1.37 | |||
| 80(2400rpm) | 130 | 444 | 112 | 98 | 1.78 | 6.07 | 1.39 | |||
| 100(3000rpm) | 160 | 546 | 138 | 120 | 1.75 | 5.97 | 1.37 | |||
| 150(4500rpm) | 215 | 734 | 185 | 161 | 1.62 | 5.53 | 1.26 | |||
| VTX1111Y* | 7.20 | BLDC | 40(1200rpm) | 55 | 188 | 47 | 41 | 1.82 | 6.21 | 1.42 |
| 53(1600rpm) | 75 | 256 | 64 | 56 | 1.85 | 6.31 | 1.44 | |||
| 80(2400rpm) | 108 | 369 | 93 | 81 | 1.86 | 6.35 | 1.45 | |||
| 100(3000rpm) | 134 | 457 | 115 | 101 | 1.83 | 6.24 | 1.43 | |||
| 150(4500rpm) | 180 | 614 | 155 | 135 | 1.65 | 5.63 | 1.29 | |||
| VTX1113Y* | 8.90 | BLDC | 40(1200rpm) | 65 | 222 | 56 | 49 | 1.82 | 6.21 | 1.42 |
| 53(1600rpm) | 85 | 290 | 73 | 64 | 1.85 | 6.31 | 1.44 | |||
| 80(2400rpm) | 130 | 444 | 112 | 98 | 1.86 | 6.35 | 1.45 | |||
| 100(3000rpm) | 160 | 546 | 138 | 120 | 1.83 | 6.24 | 1.43 | |||
| 150(4500rpm) | 215 | 734 | 185 | 161 | 1.65 | 5.63 | 1.29 | |||
| VTB1111Y* | 7.20 | BLDC | 40(1200rpm) | 55 | 188 | 47 | 41 | 1.93 | 6.59 | 1.51 |
| 53(1600rpm) | 75 | 256 | 64 | 56 | 1.95 | 6.65 | 1.52 | |||
| 80(2400rpm) | 108 | 369 | 93 | 81 | 1.96 | 6.69 | 1.53 | |||
| 100(3000rpm) | 134 | 457 | 115 | 101 | 1.90 | 6.48 | 1.48 | |||
| 150(4500rpm) | 180 | 614 | 155 | 135 | 1.70 | 5.80 | 1.33 | |||
| VTB1113Y* | 8.90 | BLDC | 40(1200rpm) | 65 | 222 | 56 | 49 | 1.93 | 6.59 | 1.51 |
| 53(1600rpm) | 85 | 290 | 73 | 64 | 1.95 | 6.65 | 1.52 | |||
| 80(2400rpm) | 130 | 444 | 112 | 98 | 1.96 | 6.69 | 1.53 | |||
| 100(3000rpm) | 160 | 546 | 138 | 120 | 1.90 | 6.48 | 1.48 | |||
| 150(4500rpm) | 215 | 734 | 185 | 161 | 1.70 | 5.80 | 1.33 | |||
| VNT1111Y | 7.20 | BLDC | 40(1200rpm) | 55 | 188 | 47 | 41 | 1.72 | 5.87 | 1.34 |
| 80(2400rpm) | 108 | 369 | 93 | 81 | 1.72 | 5.87 | 1.34 | |||
| 100(3000rpm) | 134 | 457 | 115 | 101 | 1.7 | 5.80 | 1.33 | |||
| 150(4500rpm) | 190 | 648 | 163 | 143 | 1.62 | 5.53 | 1.26 | |||
| VNC1113Y | 8.9 | BLDC | 40(1200rpm) | 65 | 222 | 56 | 49 | 1.73 | 5.90 | 1.35 |
| 80(2400rpm) | 130 | 444 | 112 | 98 | 1.75 | 5.97 | 1.37 | |||
| 150(4500rpm) | 225 | 768 | 193 | 169 | 1.62 | 5.53 | 1.26 | |||
| VNX1111Y | 7.2 | BLDC | 40(1200rpm) | 55 | 188 | 47 | 41 | 1.83 | 6.24 | 1.43 |
| 53(1600rpm) | 75 | 256 | 64 | 56 | 1.88 | 6.41 | 1.47 | |||
| 100(3000rpm) | 134 | 457 | 115 | 101 | 1.85 | 6.31 | 1.44 | |||
| 150(4500rpm) | 190 | 648 | 163 | 143 | 1.69 | 5.77 | 1.32 | |||
| VNX1113Y | 8.9 | BLDC | 40(1200rpm) | 65 | 222 | 56 | 49 | 1.82 | 6.21 | 1.42 |
| 53(1600rpm) | 85 | 290 | 73 | 64 | 1.88 | 6.41 | 1.47 | |||
| 100(3000rpm) | 160 | 546 | 138 | 120 | 1.85 | 6.31 | 1.44 | |||
| 150(4500rpm) | 225 | 768 | 193 | 169 | 1.67 | 5.70 | 1.30 | |||
| VNX1116Y | 11.3 | BLDC | 53(1600rpm) | 108 | 369 | 93 | 81 | 1.82 | 6.21 | 1.42 |
| 80(2400rpm) | 165 | 563 | 142 | 124 | 1.85 | 6.31 | 1.44 | |||
| 100(3000rpm) | 205 | 699 | 176 | 154 | 1.82 | 6.21 | 1.42 | |||
| 150(4500rpm) | 280 | 955 | 241 | 210 | 1.67 | 5.70 | 1.30 | |||
| VNB1111Y | 8.9 | BLDC | 40(1200rpm) | 55 | 188 | 47 | 41 | 1.93 | 6.59 | 1.51 |
| 100(3000rpm) | 134 | 457 | 115 | 101 | 1.9 | 6.48 | 1.48 | |||
| 150(4500rpm) | 190 | 648 | 163 | 143 | 1.7 | 5.80 | 1.33 | |||
| VNB1113Y | 8.9 | BLDC | 40(1200rpm) | 65 | 222 | 56 | 49 | 1.92 | 6.55 | 1.50 |
| 100(3000rpm) | 160 | 546 | 138 | 120 | 1.9 | 6.48 | 1.48 | |||
| 150(4500rpm) | 225 | 768 | 193 | 169 | 1.7 | 5.80 | 1.33 | |||
