加西贝拉M系列压缩机是加西贝拉压缩机有限公司出品的一款压缩机产品,位于浙江省嘉兴市,是一家环保、节能、高效冰箱压缩机的制造企业,加西贝拉M系列R600a压缩机技术参数表如下:
| Compressor | Displ. | Motor | Vol./Fre. | 制冷量Cooling Capacity | COP |
运行电容 Running Capacitor (µF) |
认证 Certificate |
| Model |
Type |
ASHRAE | CECOMAF | ASHRAE | CECOMAF | |||||
| 压缩机型号 | 气缸容积 | 电机型式 | 电压/频率 | W | BTU/h | Kcal | W | W/W | BTU/Wh | W/W | ||
(cm3) |
(V~/Hz) | |||||||||
| MM1060Y | 4.1 | RSIR | 220-240~/50 | 70 | 239 | 60 | 53 | 1.35 | 4.61 | 1.05 | / | VDE、CCC |
| MM1080Y | 5.5 | RSIR | 220-240~/50 | 92 | 314 | 79 | 69 | 1.35 | 4.61 | 1.05 | / | VDE、CCC |
| MM1090Y | 6.1 | RSIR | 220-240~/50 | 102 | 348 | 88 | 77 | 1.35 | 4.61 | 1.05 | / | VDE、CCC |
| MM1090Y | 6.1 | RSIR | 220-240~/50 | 102 | 348 | 88 | 77 | 1.45 | 4.95 | 1.13 | / | VDE、CCC |
| MM1110Y | 6.7 | RSIR | 220-240~/50 | 115 | 392 | 99 | 86 | 1.35 | 4.61 | 1.05 | / | VDE、CCC |
| MM1080Y* | 5.5 | RSIR | 220-240~/50 | 92 | 314 | 79 | 69 | 1.35 | 4.61 | 1.05 | / |
| MM1090Y* | 6.1 | RSIR | 220-240~/50 | 102 | 348 | 88 | 77 | 1.35 | 4.61 | 1.05 | / |
| MM1110Y* | 6.7 | RSIR | 220-240~/50 | 115 | 392 | 99 | 86 | 1.35 | 4.61 | 1.05 | / |
| MM1111Y* | 7.2 | RSIR | 220-240~/50 | 126 | 430 | 108 | 95 | 1.35 | 4.61 | 1.05 |
| MK1090Y | 6.1 | RSCR | 220-240~/50 | 102 | 348 | 88 | 77 | 1.55 | 5.29 | 1.21 | 3.0 | VDE,CCC |
| MK1110Y | 6.7 | RSCR | 220-240~/50 | 115 | 392 | 99 | 86 | 1.55 | 5.29 | 1.21 | 3.0 |
| MK1090Y* | 6.1 | RSCR | 220-240~/50 | 102 | 348 | 88 | 77 | 1.55 | 5.29 | 1.21 |
| MK1110Y* | 6.7 | RSCR | 220-240~/50 | 115 | 392 | 99 | 86 | 1.55 | 5.29 | 1.21 |
| MG1080Y* | 5.5 | RSCR | 220~240/50 | 92 | 314 | 79 | 69 | 1.62 | 5.53 | 1.26 |
| MG1090Y* | 6.1 | RSCR | 220~240/50 | 102 | 348 | 88 | 77 | 1.65 | 5.63 | 1.29 | 2.5 |
| MG1110Y* | 6.7 | RSCR | 220~240/50 | 115 | 392 | 99 | 86 | 1.65 | 5.63 | 1.29 | 2.5 |
| MK1070GY* | 4.9 | RSIR | 220~240/50 | 82 | 280 | 71 | 62 | 1.48 | 5.05 | 1.15 | / |
| 4.9 | RSCR | 220~240/50 | 82 | 280 | 71 | 62 | 1.55 | 5.29 | 1.21 | 2 |
| MK1110GY* | 6.7 | RSIR | 220~240/50 | 115 | 392 | 99 | 86 | 1.48 | 5.05 | 1.15 |
| 6.7 | RSCR | 220~240/50 | 115 | 392 | 99 | 86 | 1.55 | 5.29 | 1.21 |
| MM1050Y | 3.3 | RSIR | 220-240~/50 | 52 | 177 | 45 | 39 | 1.40 | 4.78 | 1.09 | / | VDE、CCC |
| MM1060Y | 4.1 | RSIR | 220-240~/50 | 70 | 239 | 60 | 53 | 1.42 | 4.85 | 1.11 | / | VDE、CCC |
| MM1070Y | 4.9 | RSIR | 220-240~/50 | 82 | 280 | 71 | 62 | 1.45 | 4.95 | 1.13 | / | VDE、CCC |
| MM1080Y | 5.5 | RSIR | 220-240~/50 | 92 | 314 | 79 | 69 | 1.45 | 4.95 | 1.13 | / | VDE、CCC |
| MM1110Y | 6.7 | RSIR | 220-240~/50 | 115 | 392 | 99 | 86 | 1.45 | 4.95 | 1.13 | / | VDE、CCC |
| MK1050Y | 3.3 | RSCR | 220~240/50 | 52 | 177 | 45 | 39 | 1.56 | 5.32 | 1.22 | 1.5 | VDE、CCC |
| MK1060Y | 4.1 | RSCR | 220~240/50 | 70 | 239 | 60 | 53 | 1.58 | 5.39 | 1.23 | 2 |
| MG1050Y | 3.3 | RSCR | 220~240/50 | 52 | 177 | 45 | 39 | 1.66 | 5.66 | 1.29 | 1.5 | VDE、CCC |
| MG1060Y | 4.1 | RSCR | 220~240/50 | 70 | 239 | 60 | 53 | 1.69 | 5.77 | 1.32 | 2 | VDE、CCC |
| MG1070Y | 4.9 | RSCR | 220~240/50 | 82 | 280 | 71 | 62 | 1.70 | 5.80 | 1.33 | 2 | VDE、CCC |
| MG1080Y | 5.5 | RSCR | 220~240/50 | 92 | 314 | 79 | 69 | 1.72 | 5.87 | 1.34 | 2 | VDE、CCC |
| MG1090Y | 6.1 | RSCR | 220~240/50 | 102 | 348 | 88 | 77 | 1.72 | 5.87 | 1.34 | 2 | VDE、CCC |
| MG1110Y | 6.7 | RSCR | 220~240/50 | 115 | 392 | 99 | 86 | 1.70 | 5.80 | 1.33 | 2.5 | VDE、CCC |
| MH1050Y | 3.3 | RSCR | 220~240/50 | 52 | 177 | 45 | 39 | 1.76 | 6.01 | 1.37 | 1.5 | VDE、CCC |
| MH1060Y | 4.1 | RSCR | 220~240/50 | 70 | 239 | 60 | 53 | 1.78 | 6.07 | 1.39 | 2 | VDE、CCC |
| MH1070Y | 4.9 | RSCR | 220~240/50 | 82 | 280 | 71 | 62 | 1.78 | 6.07 | 1.39 | 2 | VDE、CCC |
| MH1080Y | 5.5 | RSCR | 220~240/50 | 92 | 314 | 79 | 69 | 1.78 | 6.07 | 1.39 | 2 | VDE、CCC |
| MH1090Y | 6.1 | RSCR | 220~240/50 | 102 | 348 | 88 | 77 | 1.78 | 6.07 | 1.39 | 2 | VDE、CCC |
| MH1110Y | 6.7 | RSCR | 220~240/50 | 115 | 392 | 99 | 86 | 1.76 | 6.01 | 1.37 | 2.5 | VDE、CCC |
| MX1080Y* | 5.5 | RSCR | 220~240/50 | 92 | 314 | 79 | 69 | 1.83 | 6.24 | 1.43 | 2 |
| MX1090Y* | 6.1 | RSCR | 220~240/50 | 100 | 341 | 86 | 75 | 1.83 | 6.24 | 1.43 | 2.5 |
