(1)室内机(显示)故障代码(见表所示)
| 序号 | 故障代码 | 故障内容 | |
| 运行灯 | 定时灯 | ||
| 1 | 亮 | 闪烁1次/8s | 室内环境温度传感器故障 |
| 2 | 亮 | 闪烁2次/8s | 室内盘管温度传感器故障 |
| 3 | 亮 | 闪烁6次/8s | 室内风机故障 |
| 4 | 亮 | 闪烁5次/8s | 通讯故障 |
| 5 | 亮 | 闪烁7次/8s | 室外机异常 |
(2)室外机(显示)故障代码(见下表所示)
| 序号 | 故障代码 | 故障内容 | |||
| LED1 | LED2 | LED3 | LED4 | ||
| 1 | ○ | ● | ● | ● | 室外环境温度传感器故障 |
| 2 | ● | ○ | ● | ● | 室外盘管温度传感器故障 |
| 3 | ○ | ○ | ● | ● | 压缩机排气温度传感器故障 |
| 4 | ● | ● | ○ | ● | 压缩机排气温度传感器故障 |
| 5 | ○ | ● | ○ | ● | A机回气温度传感器故障 |
| 6 | ● | ○ | ○ | ● | B机回气温度传感器故障 |
| 7 | ○ | ○ | ○ | ● | 电源过、欠电压保护 |
| 8 | ● | ● | ● | ○ | 总电流过流保护 |
| 9 | ○ | ● | ● | ○ | IPM模块保护(过流、过压、过热) |
| 10 | ● | ○ | ● | ○ | 压缩机排气异常 |
| 11 | ○ | ○ | ● | ○ | EEPROM故障 |
| 12 | ※ | ● | ● | ● | A机过冷/过热保护 |
| 13 | ● | ※ | ● | ● | B机过冷/过热保护 |
| 14 | ※ | ※ | ● | ● | 电流保护 |
| 15 | ● | ● | ● | 排气保护 | |
| 16 | ※ | ● | ※ | ● | 电压保护 |
注:●-指示灯灭,○-指示灯亮,※-指示灯闪烁。
